May 8, 2007, 21:24 |
Fuseing in 6.3
I ran into a unqiue problem today. I am running a windows CCS HPC, and when I try to use the Fuse function in 6.3 it looks like it attempts to fuse them together but it never combines the interfaces and make an interior. I can take the same cas to an older version 6.2 and run it on a Basic Windows XP machine and it will fuse fine. Has anyone seen this, I used tmerge to combine the file before reading in and fusing. I am somewhat new to my job, I used Fluent on Unix and it worked fine, but the company does not use unix it has a CCS HPC set up. Any help would be appreciated.
Thanks Cory |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 14:33 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Backwards compatibility of Fluent 6.3 with 6.2 | Brian | FLUENT | 1 | April 4, 2007 21:52 |
Impressions of V 6.3 | Allan Walsh | FLUENT | 0 | January 4, 2007 11:20 |
