Subcooled boiling
Old   May 9, 2007, 15:31
Default Subcooled boiling
CFDtoy
Can someone tell me what subcooled boiling is? I have a problem where inlet "liquid temperature" is 177C with 20c subcooling? Can water exist like that? If so what properties of water should I assume?
Thanks
CFdtoy
Old   May 9, 2007, 17:09
Default Re: Subcooled boiling
Al
Water saturation pressure at 177degC is 0.95MPa, at 197degC (which is 20 degC subcooled from 177) the pressure is 1.5MPa. Hence, the conditions for your case are temperature of 177degC and pressure of 1.5MPa which is subcooled.
Tutorial for subcooled nucleate boiling Asghari FLUENT 42 December 10, 2018 11:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Stability problem due to turbulent dispersion force in a subcooled boiling model Edy OpenFOAM 7 August 10, 2011 12:00
Can CFX10 simulate the subcooled boiling near wall Gu Hanyang CFX 0 October 2, 2008 03:11
Subcooled Boiling Model. Brandon Haugh Siemens 0 December 12, 2000 14:44
