A gambit question
Old   May 11, 2007, 04:31
Default A gambit question
Adriano
Hi all, I'm using Gambit v2.3.16 and I've some trouble in drawing a particular geometry of an industrial reactor vessel. In fact inside this vessel there's a big wall perforated pipe.
I've to extract negative volume from this geometry and gambit does not consider holes geometry.
I tried with subtraction and with splitting operation without positive results.
Do You have any suggestion?
Thanks for advice,
Best regards
Adriano
Old   May 11, 2007, 08:15
Default Re: A gambit question
Adriano
I need to extract the internal fluid volume to perform a CFD simulation. The application is in biodiesel production. No aircraft wing applications!
Gambit maillage question stage81 FLUENT 0 October 1, 2010 10:06
Gambit question. Pablo Cornejo FLUENT 10 March 10, 2006 09:46
Gambit question LI Y FLUENT 2 April 6, 2003 16:59
a question about Gambit Jack FLUENT 5 February 6, 2003 06:04
an easy question about gambit brian FLUENT 3 December 2, 2002 23:58
