value of heat transfer coefficient required
Old   May 11, 2007, 05:28
Default value of heat transfer coefficient required
naren
Hi i am carrying out a natural convection analysis to find out the temperatures on a pcb , the pcb has 3 transistors on it , these also have heat sinks, and the full pcb is inside an enclosure , there is no fan , so the heat dissipation is thru natural convection only, can any one tell me the heat transfer co-efficients to be used on the pcb surface and the heat sink
Rgds Naren
Old   May 12, 2007, 12:45
Default Re: value of heat transfer coefficient required
Hugo
Doesn't fluent calculate htc for you? Otherwise, you'll have to look for some experimental correlations for htc for some configuration sililar to yours. Try Bejan's book. They are generally in terms of nusselt number, and look like this:
Nu = 0.424 Re^0.5 Pr^0.3
Hope this helps, H.
Old   May 14, 2007, 00:32
naren
Hi i am using ansys, for which we need to input the HTC, also we only know the power dissipation of the transistor and we dont have the temperature values by experiment. some one had sugested to use a Htc valueof 50 w/m2 k on the heat shink to air..... i am looking out for the data books for checking out wether we have any ready values like these..
Old   May 14, 2007, 18:04
hansen
I am having similar issue. I am using Cosmosworks for an LED lighting application. I have not found much that fits the values these programs are looking for. Most references suggest between 5-25 W/(m-sqrd *K). Avvid Thermalloy has a lot of info but it does not easily correlate into these applications. Good luck, if I find something. I will stop back here.
Old   May 15, 2007, 00:27
naren
Thanks, i found in one of the books that a general value of 10 W/(m-sqrd *K). is a good approximation for metals... any way thanks for he info.
Heat Transfer Coefficient Alberto Schroth FLUENT 17 February 10, 2020 08:40
BOILING HEAT TRANSFER COEFFICIENT John CFX 3 April 4, 2012 17:50
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 15:35
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Heat Transfer Coefficient los OpenFOAM Running, Solving & CFD 5 January 31, 2010 17:44
