How to fix the temperature at the interface in VOF |
May 16, 2007, 05:52 |
Hi, when I am modelling the VOF, how can I fix the temperature at the interface of the two fluids? or how can I fix temperature throughtout the two fluids? Writing a UDF for volume fraction of 0.5? but how to specify it in fluent?
Any suggestion is appreciated. Thanks. |
May 21, 2007, 14:43 |
Re: How to fix the temperature at the interface in
You should first determine the cells where the 0.5 vol.frac. is located. Then you set the temperature at desired value.
Adaptative mesh around interface with VOF model | baechtel | FLUENT | 0 | May 12, 2009 02:35 |
No results for solid domain | Gary Holland | CFX | 10 | March 13, 2009 04:30 |
VOF Lagrangian Interface Tracking | Kam | CFX | 3 | November 5, 2008 19:08 |
masse source at the interface in VOF model | Marco | FLUENT | 0 | September 26, 2007 06:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
