May 16, 2007, 14:02 |
Fast Fourier Transform
Hi everyone, I would like to analyse the turbulent spectrum of the flow over a bluff body. As I'm simulating using FLUENT all the data is on the Spatial space and I need to use FFT to transform the data to the Fourier space.
In order to compare my simulation with other results I got the velocity (U, V, W) on the same point that the paper presented. Also I have the code to compute the FFT. So my question is about how to do it. To obtain the spectrum, should I use the FFT of the V velocity and from the results get the square ? For example: FFT(V) = R+iIm The one dimensional streamwise velocity spectrum is R^2+Im^2 plotted in a log graph? What about the frequency on the X axis? How do I calculate? Does any one know about it? Thanks Lourival |
Fast Fourier Transform | alastormoody11 | STAR-CCM+ | 0 | January 20, 2011 22:49 |
Poisson equation fourier transform before discretization | yohey44 | Main CFD Forum | 0 | November 9, 2010 12:00 |
Fast Fourier Transform of CL signal | Sachin Paramane | Main CFD Forum | 0 | June 11, 2007 07:51 |
Fast Fourier Transform | Lourival | Main CFD Forum | 21 | June 7, 2007 00:53 |
Fast Fourier Transform | Sara | Main CFD Forum | 2 | February 14, 2006 07:51 |
