Turbulent dissipation rate effect turbine torque??
Old   August 24, 2012, 15:12
Default Turbulent dissipation rate effect turbine torque??
LEE SE DONG
sedongjjang is on a distinguished road
Hello^^
I want to know turbulent dissipation rate (specific dissipation rate) effect.
I am simulating a horizontal wind turbine using the K-epsilon turbulence
and sst k omega turbulence model.
when i see the torque result of the simulation, i know that the results is
very different from the reference. (especially, K epsilon turbulence)
As you know, there are a lot of turbulence boundary condition.
I use the turbulence intensity and turbulence viscosity ratio.
When I input the large viscosity ratio, it makes the dissipation rate small
according to the formula; vice versa.
( you can see the formula http://www.cfd-online.com/Wiki/Turbu...ary_conditions )
So, I knew the dissipation rate effects turbine torque.
But I think that specific dissipation rate in K omega model doesn't effect
the result in comparison with the k epsilon model. Is that true??
In conclusion, I want to know the two things.
first, How does the dissipation rate effect the wind turbine torque?
second, is it true that SST K omega turbulence model is not sensitive to
the dissipation rate in comparison with K-epsilon model?
(in K-omega model, specific dissipation rate!)
I am waiting for the kind response.
sedongjjang is offline   Reply With Quote
Dissabling turbulent dissipation lindner OpenFOAM 3 February 7, 2021 14:51
changing a variable (turbulence dissipation rate) formolation m.beh Fluent UDF and Scheme Programming 6 November 7, 2016 06:53
Turbulence dissipation rate bitkiz CFX 1 November 16, 2011 10:46
CFX12 rif errors romance CFX 4 October 26, 2009 14:41
How to calculate Torque for francis turbine manish CFX 4 March 15, 2007 03:57
