Fluent 6.2.16 on cluster saves data files slowly |
May 15, 2007, 06:37 |
Hello! I have following problem regarding Fluent on a cluster. The calculations run fine but when I want to save with the autosave command it takes up to 1 hour to save a 70MB large data file. I also get following message in the command window which I never had before:
"Host receiving summary from compute node zero. Writing "/array/clemens/estonia/empty/deck4_vinlet_poutlet-0001.dat"... Host receiving injections from compute nodes. freeing host particles. Done." Does anybody know what could cause this slow down? Thanks for any help! C. |
May 18, 2007, 06:52 |
Re: Fluent 6.2.16 on cluster saves data files slow
The messages you get on the console are normal, don't be worry about them. Which communicator do you use? try the -pnet option, is not the fastest one in communication, but for writing files in parallel is the best.
May 21, 2007, 09:54 |
Thanks for your help!
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 04:16 |
Data Transfer - Polyflow to Fluent to Abaqus | Bob Carson | FLUENT | 0 | March 27, 2007 09:31 |
Tecplot Variable Names For Fluent Data Files | Simon | FLUENT | 0 | September 22, 2005 10:44 |
Structure of case and data files | Frederic Nicolas | FLUENT | 1 | August 4, 2000 11:54 |
Binary files stored by Fluent | Jackson | FLUENT | 1 | April 2, 2000 21:58 |
