2D Compressor cascade study using DFLVR blade
Old   May 24, 2007, 14:31
Default 2D Compressor cascade study using DFLVR blade
kiran
hi everyone,
i am analysing 2D compressor cascade using DFLVR blade, by varying its leading edge i am unable to find any standard test run of this blade,
if any one has done 2d-COMPRESSOR sTUDY THEN PLS HELP, i am facing a problem, in the result i am getting, i am using unstructured grid, inflow parameter as Pressure farfied(i am stimulating COmpressive flow at mach 1.4) and using a alue of 101325 pascal. and outflow as 1000pascal. i am using spalar allmaras scheme.
i am not getting good results. and also the grid is pretty schewed.
it would be great if i get some standard run case. which i can follow. its urgent.
i have to finish the work in 2 weeks
thanks in advance
Old   May 24, 2007, 15:01
Default Re: 2D Compressor cascade study using DFLVR blade
Razvan
If you would like to send me the geometry, then I could prepare a ref. case for you.
Razvan
Calculating lift force of a wind turbine blade problem LittleBart CFX 4 June 29, 2011 02:33
Rotating blade in circular/square vessel (Salome+OpenFoam) voingiappone OpenFOAM 0 May 19, 2011 11:38
how to study a simple rotating blade? signofra CFX 1 April 1, 2010 06:23
Meshing a 3D, tapered and twisted blade with Gambit-TGrid teskio ANSYS Meshing & Geometry 0 July 3, 2009 10:36
Flow study through Turbine Blade passage Subrata FLUENT 1 May 4, 2007 11:28
