May 25, 2007, 05:49 |
plz help ,urgent ,vof model steady state
hi
i tried with the steady state formulation as razvan told and used presto scheme only, still its giving no change in the level of liquid in the bowl. i used the same mesh or case file as given in the tutorial problem given in fluent manual as 16th problem ,i just changed the unsteady to steady state and used presto scheme for discretization still no change in level of liquid though the solution is being converged .plz tell me whats the problem .either the issue is that i cant use vof model in a rotating bowl filled with some initial fluid level or what ? i am not able to get the reason behind it . if cant use then why not , why unsteady formulation should only be used for vof model for a rotating bowl filled with some liquid to an initial height of 1/3. plz guide me . regards Garima. |
Display Modes | |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Appropriate model for turbulent, steady state pipe elbow flow | milos | OpenFOAM Running, Solving & CFD | 4 | July 9, 2009 02:24 |
regarding steady state discrete phase calculations | hajszan_gyula | FLUENT | 1 | February 28, 2006 01:32 |
steady state creeping flow | dominik | Main CFD Forum | 4 | March 29, 2004 09:29 |
About the difference between steady and unsteady problems | Lisa | Main CFD Forum | 11 | July 5, 2000 14:37 |
