May 11, 2007, 05:50 |
3D plots in fluent
hi fnds, can anybdy help me to plot 3D graph of variables in fluent thank you
Bharat Makwana |
May 11, 2007, 08:37 |
Re: 3D plots in fluent
fluent can't plot 3D graphs; you can extract data by exporting them and plot them in excell or in Matlab (better). A
May 11, 2007, 13:06 |
Why is Matlab better?
May 14, 2007, 04:58 |
It just is!
May 15, 2007, 12:47 |
Excel is quick and dirty. I like it!
May 17, 2007, 11:33 |
how can we extract data from fluent. Actually I want to plot axial distantce V/s Radial velocity (is dimensional less)i.e radial velocity/ (r*w), where r = radial coordinate & w = rotational velocity of refernce frame, These at different times that are also dimensinal less t/Ts t = actual flow time and Ts = sqrt(w)/sqrt(E) E = ekman number.
May 24, 2007, 12:17 |
If your case is time dependent, save frequently (by outsave) and run a macro that save in a ascii file the variables that you need. After import them in matlab and good luck
If you have just performed the calculation, write a matlab cod that write a fluent journal file such as: read-case xx-1.cas read-data xx-1.dat //file/export/ascii pathFile\nomeFile-1.YYY nomeSurfaceOrInterior () yes listOfVariables read-case xx-2.cas read-data xx-2.dat //file/export/ascii pathFile\nomeFile-2.YYY nomeSurf () yes listOfVariables .... read case xx-N.cas read data xx-N.dat //file/export/ascii pathFile\nomeFile-N.YYY nomeSurf () yes listOfVariables hope it's helpful good luck A |
May 24, 2007, 13:32 |
There is a matlab code that reads all the data is acsii in one big file and you can use it to plot the data. I don't think you can do a 3D plot with 2 varaibles.
Here is where you can get it: http://www.iit.edu/~mostmoh/visual.html |
May 25, 2007, 12:22 |
#9 |
hi
I din't understand what u told me. i dont know how to write code in matlab. can u please explain in detail or do they have any documentaion regarding this. Thanks Ketan |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 03:22 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
fluent parallel problem in win7 x64 system | dunga82 | FLUENT | 8 | April 19, 2012 20:23 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Master node in parallel computing only distirubtion | syadgar | FLUENT | 1 | September 8, 2009 16:41 |
