import autocad file
Old   May 31, 2007, 09:27
Default import autocad file
ritmat
i am trying to import a geometry from autocad. I am importing a *.sat of 3Mb into gambit but it is really slow. I have a great processor and i dont think the size of the files is so big. in gambit, i go to file / import/ asci Do you know if i have another way to export this file into ganbit? thank you
Old   May 31, 2007, 09:36
Default Re: import autocad file
R.
sat should be your best bet. Gambit can import up to version R15.
Slow import times might be a sign of geometry that needs healed.
Try the 'binary' option in the import dialog.
Old   May 31, 2007, 09:40
ritmat
actually the time to import its ok but when i want to move the geometry is too slow. It is why i was wondering if there was no way to import it with maybe a bit less quality?
Old   May 31, 2007, 12:16
R.
not really.
I suggest a better video card.
Old   June 1, 2007, 03:29
ritmat
i dont think as well that is the video card. Actualli i saw that gambit is only using one CPU from the dual core processor. Do you know anyway to work with parallel processor in gambit? thank you
Old   June 1, 2007, 12:19
R.
nope. Gambit does not run in parallel and never will.
If the display is slow when panning/rotating then a faster video card will help.
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
import an AUTOCAD file to Mentat leila Main CFD Forum 0 April 23, 2008 04:04
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
