report surface area WITHOUT solit
Old   June 1, 2007, 07:18
Default report surface area WITHOUT solit
Ralf Schmidt
Hi!
I have a geometry, with fluid AND solit meshed. Now, I made several lices in that geometrie and I want to report e.g. the average velocity in main flow direction (y-vel.) along the y-axis of the FLUID.
I use report-> surface integral, BUT Fluent uses for calculation of area averaged values the whole surface area WITH the solit area!
So, in my case the area averaged y-velocity in the main flow direction does not changes (what is of course right, considering constant mass flow and averaging about the whole area ignoring the solit blocking).
How to report the values averaged ONLY on the fluid area? That problems is also with the other velocity-components, pressure, temperatur (the solid is hot!) ...
Any Idea??? Ralf
Old   June 1, 2007, 10:23
Default problem solved
Ralf Schmidt
Hi!
Use "iso-Surface" of constant grid.. y coordinate, from zone fluid
That works!!!
Surface integrals report: incident radiation Novice FLUENT 3 February 8, 2018 09:53
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Finite Area Classes and Surface related Utilities philippose OpenFOAM 10 December 9, 2011 11:42
Flame Surface Density. Burn Ing Main CFD Forum 3 December 5, 2004 17:12
