Non-spherical, inert particle tracking in FLUENT
Old   May 30, 2007, 10:21
Default Non-spherical, inert particle tracking in FLUENT
Amanda
Hi!
I'm currently working on injection of inert particles into a combustion chamber. If the particle involved is non-spherical, how can I define the shape? I can only see 'diameter' when I set the injection in FLUENT. Please help!! Thanks!
Old   May 30, 2007, 11:26
Default Re: Non-spherical, inert particle tracking in FLUE
margaret mkhosi
Hi, FLuent has an option for nospherical particles under the drag law, but you will have to specify the 'shape factor.
Old   May 30, 2007, 12:24
Amanda
something that I'm curious about --> let's say I'm considering a long cylidrical shape (length is relatively long compare with its diameter), when I specify the 'shape factor' under the drag law, will the rotational motion of that cylinder being considered properly?
Thanks!!
Old   May 31, 2007, 06:22
Henrik
Hi!
The shape factor is the ratio of the surface area of a sphere having the same volume as your particle to the actual surface area of your particle. It is used by Fluent when determining CD for use with the drag force. As it does not include any information on exactly how your particle differs in shape from a sphere, it will not be possible for Fluent to correctly considered any rotational motion of your particle. If this is important for your simulations, maybe it will be easier to use a custom drag law that you may implement via a UDF.
Hope this helps!
/Henrik
Blood Damage Modelling via Particle Tracking in a Centrifugal Heart Pump scatman CFX 7 January 8, 2018 00:59
particle tracking Wenqing Zhang CFX 15 August 3, 2013 06:02
Inert particle tracking sujay CFX 0 April 9, 2011 00:05
Coal Particle Tracking michael FLUENT 4 November 9, 2007 07:27
particle tracking Gab CFX 0 January 5, 2006 16:12
