June 1, 2007, 09:19 |
implicit or explicit
I try to model hydrogen-oxygen diffusion in air. I would like to know which solver formulation is better between implicit and explicit. Thanks |
June 1, 2007, 09:58 |
Re: implicit or explicit
I think the impicit solver is better and it's more accurate but it take more time.
June 2, 2007, 06:45 |
In my opinion, such a problem is evolutive so it should be solved using unsteady formulation. In this case, the theory and the numerical tests say that the explicit unsteady formulation is more accurate then the implicit unsteady.
The implicit formulation is more diffusive ,especially at CFL>1, thus it amplifies the chemical species diffusion. If we add the numerical diffusion induced by the discretisation algorithms and the one generated by the grid, we end up with totally wrong results. So, I will recommend a carefully constructed hexa-dominant mesh with low skewness and sufficient density in the areas with high species gradients, high order discretisation schemes (at least 2nd order upwind, MUSCL would be better, especially if tri/tets are present), an unsteady explicit solver formulation, with CFL=1 (you can increase it upto 5 ,but some error should be expected). Also, if there are jets, shear layers, or swirling flows involved, you need a very good turbulence model, so RSM is a minimum. Good luck, Razvan |
Implicit versus Explicit | Deepak | Main CFD Forum | 17 | November 7, 2015 13:14 |
ddt explicit or implicit with courant number!! | mrshb4 | OpenFOAM | 0 | December 13, 2010 11:13 |
From Explicit to Implicit formulation | emanuele | FLUENT | 2 | October 4, 2006 14:17 |
Euler (explicit or implicit) | anybody | Main CFD Forum | 2 | May 8, 2006 02:12 |
implicit vs explicit | pXYZ | Main CFD Forum | 2 | April 21, 2006 09:48 |
