September 7, 2020, 13:23 |
forced convection in Fluent
Ivan
Hi everyone,
I need to calculate via Fluent the cooling of a 1300 K titanium sample immersed in a fluid that flows at 300 K (and therefore the heat exchange between them) for a transient of 15 seconds. By doing the simulations, in addition to having set the boundary conditions, through Cell Zone Conditions, I see that I can only set a fixed value of the temperature, so the simulation only shows me how the fluid warms up, and not how the specimen cools. Through the named expression I tried to set up a cycle of this type and defining: TStart = 1300 [K] TTarget = 1000 [K] TMin = Minimum (TotalTemperature, ["heatcube"] TCurrentCube = Average (TotalTemperature, ["inlet"], Weight = None) {inlet = 300 K} TAdjust = TCurrentCube + (TTarget-TMin) * relax {relax = 0.9} TCube = IF (iters_per_timestep <10, TStart, IF (mod (iters_per_timestep + 1,30) == 0, TAdjust, TCurrentCube)) {iter / time step = 30 in Run Calculation} And I impose TCube in the Boundary Conditions -> Wall -> {for all the walls adjacent to the specimen}. but this method doesn't work and I don't know how to implement it on UDF. I have also tried using the patch command in Initialize, but the specimen temperature still doesn't decay. Can anyone kindly help me? regards ikki |
September 8, 2020, 04:56 |
Moritz Kuhn
Rep Power: 17 |
I would do it in this way. Start with a steady state solution. The cold titatnium sample in the 300 K flow, solve until convergance. Then switch to transient, go to the initialization panel and patch only the temperature of the titanium cell zone to 1300 K - start the simulation with small time steps. In this way the temperature of the titanium will decay and you do not need an UDF.
September 8, 2020, 05:58 |
Ivan
Hi MKuhn,
I'll try your step. Thx very much |
Forced Convection Process In Ansys | Exterot | ANSYS | 0 | March 23, 2019 14:26 |
Is it possible to model natural convection in a 2D horizontal model in fluent | caitoc | FLUENT | 1 | May 5, 2014 13:32 |
heatsink with forced convection | siva | FLUENT | 0 | September 26, 2008 00:05 |
Turbulent Forced Convection | Tim | FLUENT | 1 | October 1, 2006 07:41 |
Forced Convection | Tim | FLUENT | 4 | October 1, 2006 00:48 |
