turbulence model
Old   June 11, 2007, 13:37
Default turbulence model
elkan
hi
I am making a simulation 3D airfoil with models S-A and K-e, as of them it is better? the results that I obtain are different, being the greater coefficients drag and lift for k-e than it means this.
I hope that they can help me
thanks
Old   June 11, 2007, 13:43
Default Re: turbulence model
amir
Hi i had a similar problem and i use k-e .my results were better.but i think u should compare it whit exprimental results. Amir
Old   June 11, 2007, 15:50
elkan
but I do not have experimental datas with which to compare, as model is the suitable one?
Old   June 13, 2007, 03:42
Dr. Flow Squad
k-epsilon tends to "stick" more to the surface than K-omega bassed SST. I don't know about SAS model, but I would expect it to be superior of the both.
Ive done some test between k-e and SST on a circular cylinder. Have a look compared to vanDyke's book:
<CENTER> Exp. Re=100,000, Instantaneous plot:
k-Epsilon Stationary:
SST Stationary:
</CENTER> - Dr. Flow Squad
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
Fan heater model: what turbulence source to use? andy20 CFX 7 March 3, 2008 16:42
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 16:15
