June 13, 2007, 10:30 |
Low Speed flow in Micro Gravity; what model?
I am modeling the airlfow in a Rack Volume on the International Space Station using Fluent. What Viscous model (ke, kw,...) would be most accurate for that kind of flow? The maximum airspeed is right around .5 m/s and that is only in a few localized areas. Average speed is right around 5cm/s. I have been using the kw model but I am not so certain that is the best choice -- no real reason for my scepticism though... Any wisdom would be appreciated! Brice
Help: apply B.C. in my granular flow model ? | Derek Jing | FLUENT | 1 | January 8, 2020 21:38 |
Turbulence model for low Reynolds number flow? | Nokadu | Main CFD Forum | 3 | May 26, 2013 11:42 |
About compressible flow at low mach | hit | Main CFD Forum | 2 | October 26, 2009 21:21 |
Can OpenFOAM generate flow at the speed of light? | Michel_sharp | OpenFOAM | 6 | October 24, 2009 04:09 |
Free Surface Gravity Driven Flow | Rupp Carriveau | FLUENT | 4 | June 14, 2001 16:54 |
