June 21, 2007, 08:38 |
Storing Surface Area of each cell in a file?
I'd like to write out the surface-area of each cell in an ASCII-File. In the FLuent-User Guide, I found this: "Cell Surface Area (in the Adaption... category) is the total surface area of the cell, and is computed by summing the area of the faces that compose the cell." which sound pretty interesting to me, but I only need the areas "touching" a selected surface (these cell-areas that I can see when displaying the results by using the Contours-Panel and selecting that Surface). In the Functions to write in the Export-Panel, I found Z-Surface Area, as well as Cell Surface Area (which is dropped out as shown in the citation above). Would the "Z-Surface Area" be the correct value, that I need, or could you propose another function? I figured out that the sum of all Z-Surfaces is pretty close to that value that I get when calculating the whole area by using the "Projected Surface Areas". I hope you understood my question and I would be glad if anybody could give me a hint about it. Thanks in advance, MA |
Can Flow-3D plot the free surface area in Iso-surface or colour variable? | therockyy | FLOW-3D | 1 | June 20, 2010 19:36 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
Results saving in CFD | hawk | Main CFD Forum | 16 | July 21, 2005 20:51 |
