What is the Flow domain?
Like Tree1Likes
  • 1 Post By Ahmad
Old   June 20, 2007, 10:56
Default What is the Flow domain?
Naghman Khan
I'm new to CFD so this may seem like an incredibly simple question to you all, but what is the actual flow domain of say a Brick created using the volume command.
If I were to create a brick, this would be a solid brick as confirmed when viewing through the shaded view. Is this solidity real or virtual, I mean will air actually flow through the volume or do I need to make another slightly smaller brick than subtract this from the original brick to give a hollow volume shaped like a brick?
Thanks all, appreciate it.
Old   June 20, 2007, 17:39
Default Re: What is the Flow domain?
Ahmad
Hi
The flow domain is the volume in which the flow takes place (a 2D model assumes a unit depth into the screen). You don't have to draw a smaller volume for the flow. The walls (faces) of the brick (volume) are the boundaries of the flow domain. The shade view only shows you the "outer" faces of the domain, so it is hollow by default (unless you specify it as a solid in the "continuum type" panel).
Regards
cleoo likes this.
Old   June 21, 2007, 04:32
Naghman Khan
Ahmad, thanks again bro, that made perfect sense.
Old   June 21, 2007, 10:44
Ahmad
My pleasure.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Modeling the flow domain in Icepak saisanthoshm88 Main CFD Forum 0 April 11, 2011 08:31
Porous domain in a flow field rikio CFX 7 August 25, 2009 22:39
Domain for Pipe Flow Swarup FLUENT 0 September 28, 2005 23:25
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
