use of C program
Old   June 28, 2007, 06:40
Default use of C program
Vedavyasa M
Help me
If i have datas for each time, i.e., for 1st hour, x =3, so on, is it possible to use those datas as input to the CFD problem. If so please explain me.
Old   June 28, 2007, 20:25
Default Re: use of C program
Tomasz Bednarz
V, please specify your problem more clearly...
Old   June 29, 2007, 06:22
Vedavyasa M
Hello Tomasz,
I will calculate for example solar radiation heat flux for different times say from morning 6'o clock to evening 6'o clock, on a horizontal plate using say polynomial equation. Now I want to use these datas as input to a problem. How to use these datas for solving the problem using fluent.
Old   June 29, 2007, 06:59
JSM
From your question, I think you want to give the heat flux as the time dependent property.
If my understanding the question is correct, then you can use read-transient-table option. It is available in TUI mode. Refer user guide for more details.
Hope it will help,
JSM
Chemkin Forums? PSR.f program help? johnjohnmulley Main CFD Forum 2 August 5, 2013 07:53
Which opensource and free CAD program? Xwang Main CFD Forum 1 October 24, 2010 17:29
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 11:55
Problem in program tib FLUENT 0 January 28, 2004 14:13
How to write a simple program ?? kokey FLUENT 0 March 19, 2002 10:21
