July 13, 2007, 06:13 |
error
Hi to all, I found strange error during simulation. I start simulation with few time step. then i check the contours but strange i found error like this.
Error message from graphics function QDolly_Camera: Syntax error during expansion of '.' - '.' referred to, but no segment is open Then i started continuing my simulation that goes well. after few step i check contour plot again i found same. what is this? how can i cure this error? reply whatever u know @ such error whether u came across the same error. regards |
July 13, 2007, 07:38 |
Re: error
I think the problem is with the display itself. Before starting simulation check by displaying the grid..same error shud occur... What command you give for starting fluent? Try giving this....'fluent <version> -driverX11 &' Arpit |
July 13, 2007, 08:56 |
Re: error
Hi, where shall i give this command - in TUI?, but that donot work. can u pl elaborate this i find this all the time in same machine for earlier saved case and data file also.
thanks for reply |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
c++ libraries and solver compiling | vaina74 | OpenFOAM Installation | 13 | February 3, 2012 17:43 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
