July 13, 2007, 15:25 |
UDF to monitor force
This is a basic question about FLUENT, how can I monitor the force value that I obtain from REPORT-->FORCES-->WALL. I tried SOLVE-->MONITORS-->FORCE-->WALL, but this monitors the drag coefficient. Do you have any suggestions? If a UDF is needed, can you give me a sample UDF. |
July 16, 2007, 07:58 |
Re: UDF to monitor force
If you set the reference values in report--> reference values so that F=0.5*density *area* velocity^2*CD then the two methods will give the same thing. Hence setting density to 2, area to 1 and velocity to 1 will do exactly this. This will not affect the solution values only the way the coefficient if calculated.
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
