to draw tech plot using fluent results(case& data) |
July 18, 2007, 13:13 |
hi Iam madhuri,i would like to know how to draw techplot using flient case and data files. iam trying to show the swirl flow in the pipe by a 3-dimensional view of the axial radial and tangential velocities on a surface. can any one give me an idea to do this
Thanks |
July 18, 2007, 13:21 |
Re: to draw tech plot using fluent results(case& d
you can export the fluent results to tech plot through file-export-techplot option....
but im not sure about the 3d capabilities of tecplot |
July 18, 2007, 13:43 |
hi madhuri i v techplot 10 .just import the files in techplot using the option under file menu
Fluent: XY plot from file | Ianto | FLUENT | 7 | October 13, 2023 15:29 |
OpenFoam to Fluent data conversion Problem | vemps | OpenFOAM | 1 | August 8, 2011 02:30 |
how to compare unsteady state problem results from FLUENT with Experimental data? | cuddaloreselvam | FLUENT | 0 | July 10, 2011 08:25 |
recording data from the XY plot | Karan | Main CFD Forum | 0 | February 1, 2009 18:47 |
Problem of import fluent data to ilight fieldview | seasoul | FLUENT | 3 | September 9, 2008 22:36 |
