Coal Combustion - Devolatilization Rate Unit
Old   July 17, 2007, 16:32
Default Coal Combustion - Devolatilization Rate Unit
Amanda
Just wondering if I can change the unit of reporting results of devolatilization rate of burning coal from kg/s (Fluent default) to other units, say kg/m3s ?
Thank you.
Old   July 18, 2007, 08:25
Default Re: Coal Combustion - Devolatilization Rate Unit
ledombo
I think your stuck with what Fluent uses. I usually write output files and import to excel/MATLAB where you can change the units manually and do multi-plots and such.
Old   July 18, 2007, 09:42
Amanda
Ledombo,
thanks for ur reply. But does it make sense to report devolatilization rate in kg/s ? is it a common unit used?
Old   July 18, 2007, 12:55
ledombo
Yes, I think kg/s makes sense and is an SI unit.
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 09:39
Turbulent Dispersion for Coal Combustion gravis CFX 2 March 23, 2010 23:56
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 08:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 19:43
Coal combustion with Fluent 4.5 or 5.0! Sriram Popuri Main CFD Forum 2 July 24, 1999 11:34
