How to model this case in fluent?
Old   July 13, 2007, 17:34
Default How to model this case in fluent?
hjzy
Hi, fluent fans:
I have a problem in solve this case:
the tube has solid walls all around - same boundary conditions on all four sides - left side, right side, top side, and bottom side. There is a high pressure region on the left and a low pressure region on the right separated by a diaphram. At t=0, the diaphram is removed and the pressure will create a flow from left to right.
Which kind of model can I use to simulate this condition. I can try it as a 1d or 2d problem.
Thanks!
Old   July 16, 2007, 17:53
Default Re: How to model this case in fluent?
hjzy
this is a shock tube problem. I have tried many method, but still can not the result, did any one can help?
Thanks in advance!
Old   July 17, 2007, 14:20
sujith
This problem should possible using unsteady density based solver. you have to patch the initial values of pressure. I havn't tried this myself. If you have already tried this and had any difficulties, please share it with us
Old   July 17, 2007, 19:11
yzheng
I have tried this problem, but still can not get accurate result.
I just make a rectangular, 8.2m Ã- 2m, four sides all defined as walls, and make a line just between the center(x=0) as an interior, then make two zones, left has high pressure at about 3.5atm and density=0.445, the right side has the lower pressure at about 0.5atm and density=0.5. I just use patch after the initialize.
In fluent, read the case, then check the grid, it's ok. Define-> models->solver->coupled->unsteady Define->energy Define->viscous ->k-epsilon(2-eqn) Define->material ->ideal gases Define->operation condition ->operation pressure=0 Define->boundary condition(nothing need to define)
Solve->controls->solution controls->pressure velocity coupling->piso
Solve->monitors->convergence criterion(change all values to 0.000001)
Solve->initialization->gauge pressure=3.5atm, temperature=400k
Solve-> initialization->patch initialization->set the pressure for the left zone3.5atm, temperature=2789k, set the pressure for the right zone0.5atm, temperature=400k, set all the velocity=0
Solve->iterate, set the time step size=0.0001s, then iterate. But it can not convergence, after about 500 steps, it is said, divided by zero.
The problem is the pressure of the left side changed a lot, especially at the x=-4.1m, but the center is changed not so much, and the pressure in the right zone changed a little near the center. This is not as expected, I don't know why?
Any advices? Thanks in advance.
Old   July 17, 2007, 19:13
yzheng
I only have the version of 6.2, so it don't have density based solver.
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 17:54
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
self-built model embeded in FLUENT Jiedong FLUENT 0 January 22, 2009 02:57
heat transfer with s2s radiation model in fluent D. L. FLUENT 3 July 31, 2008 07:40
Covert Star-CD model to FLUENT Lam Siemens 6 June 24, 2003 20:21
