Memory problem
Dear all,
I am using 4 GB Ram and Dual processor system, i am running one simulation in that cell count around 20 lacks, while running its giving error and exiting from the run. this is the error message i got. iter continuity x-velocity y-velocity z-velocity time/iter Error: 1000000: Failed to allocate 56.25MB memory (..\..\src\amgif.c:1064) Error Object: () |
Re: Memory problem
do you use coupled solver? because coupled consumes more memory (around double the segregated solver)
have u activated both of the processor (you have dual)? because I read in a fluent newsletter, that you must activate both processor first. |
Re: Memory problem
is there any suitable way to remove this error??...means find out the nodes of grid which will be sufficient according to memory ??
Re: Memory problem
there is unwitten rule that 1 GHz is for 1 million grids (for segregated), around 500.000 for coupled. but this number is just approximation
