Diffusion from fluid region into porous tissue.
Old   August 3, 2007, 07:34
Default Diffusion from fluid region into porous tissue.
Lindz
Can any one help me please?
Im modelling oxygen diffusion from fluid into porous tissue. I want the fluid flow stationary and want to see the effects of the oxygen diffusing into the tissue until equilibrium is reached. When i use the exact boundary conditions needed and include an inlet velocity i get what i would expect for the flow field; so the porosity definitions should be correct. However, when i try to model the species transfer, the concentration of oxygen is the same within the tissue as outside the tissue to start with. Is there a way of specifying a lower concentration of oxygen for the tissue as it wouldn't let me modify oxygen content in the materials panel.
Also, for the diffusion into the tissue, would i need to write a UDF for the source term within the tissue as im new to all this stuff.
Many thanks Lindz
[Other] How do you define a cell zone or region for porous? bigbang OpenFOAM Meshing & Mesh Conversion 6 March 18, 2016 17:42
Radiation at interface between fluid and porous domain Hitch8 CFX 19 April 20, 2015 06:24
spercritical fluid flow in porous media cachen FLUENT 3 November 10, 2007 02:20
Heat transfer from porous medium to fluid Ralf Schmidt FLUENT 1 October 30, 2005 06:21
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 15:16
