need help for using user defined heat exchanger
Old   August 4, 2007, 20:18
Default need help for using user defined heat exchanger
sinha
I defined a heat exchanger and used it as a boundary condition in a simulation. However, I could not find the report which describe the working properties of the heat exchanger, such as the coolant outlet temperature, the pressure drop and so on. Can anyone tell me where I can find it? (In the turorial, it says that the report would be in define->model->heat exchanger -> report. However, I could not find it there.)
Thanks a lot!!
Old   August 6, 2007, 03:03
Default Re: need help for using user defined heat exchange
ritmat
from user guide, hope it help
To view the computed values of total heat rejection, outlet temperature, and inlet temperature for the entire heat exchanger, excluding any macros, you can use the following text command:
define user-defined heat-exchanger heat-exchanger-report
When prompted, specify the fluid zone for which you want to report the results.
To report the results for the macros, you can use the following text command:
define user-defined heat-exchanger heat-exchanger-macro-report
Specify the fluid zone for which you want to obtain information.
To view the connectivity of the heat exchanger groups, use the text command
(report-connectivity)
Old   August 6, 2007, 17:16
sinha
Thanks a lot
Heat Exchanger Model - urgent JSM FLUENT 6 September 22, 2007 04:25
Heat Exchanger...TWO Walid CFX 2 July 11, 2005 19:04
BIG TROUBLE with heat exchanger and porous media!! Andrea FLUENT 0 February 20, 2005 07:49
User Defined Function for convection coefficient ereiss FLUENT 1 July 8, 2004 16:10
Offset strip-fin heat exchanger Dipak Phoenics 1 July 19, 2000 10:46
