Atmosphere
Hello, I want to simulate air being sucked into a pipe connected to pump. I want to see how the velocity vectors are formed and what will be the plume of air being sucked in.
Example: I want to see how air around a vacuum cleaner duct behaves as it gets sucked in when you switch on the machine. What kind of boundary condition can I give to the domain. Thank you. |
Re: Atmosphere
Pressure inlet with total pressure of 1 atmosphere (abs). Make sure it is far enough away from the device.
