How to output unsteady velocity profiles?
Old   August 7, 2007, 15:56
Default How to output unsteady velocity profiles?
Jason
I am running an unsteady case through a tube and would like to plot a 3D graph of velocity profiles at different cross sections. I would like to write a UDF to output velocity vs radius vs time. Does anyone have a UDF that would achieve this and also how to implement it?
Old   August 7, 2007, 16:01
Default Re: How to output unsteady velocity profiles?
Joe
You can do this all within a postprocessor e.g. fieldview.
Old   August 7, 2007, 16:57
Jason
I need to find a way to output my data. I know of two methods currently but both require a large amount of files. I would like to be able to output the data into one file. From there I know how to process this data. I was going to use: DEFINE_EXECUTE_AT_END for my UDF but am unsure how to access different faces to determine velocity.
Old   August 8, 2007, 09:40
bluelc1982
You can try the Macro Lookup_Thread to find the face you wanted.
UDF Unsteady velocity parabolic profile Rashad FLUENT 3 October 1, 2018 15:27
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
UDF Unsteady velocity profile Rashad FLUENT 0 February 27, 2008 14:57
output data for unsteady flow case wieke Main CFD Forum 0 September 30, 2003 04:40
Unsteady output keith CFX 1 July 12, 2001 07:29
