Urgent please!!!! Error messages in Fluent
Old   August 8, 2007, 08:29
Default Urgent please!!!! Error messages in Fluent
Sharma
Hi all, Thanx for ur time and attention. I have created a cas file by appending two cas files and also created the interface (coupled) between them. When I try to open the new cas file, it gives the following messages:
Error: access: unbound variable Error Object: get-var
Error: CDR: invalid argument [1]: wrong type [not a pair] Error Object: #f
I have checked the original two cas files and there seems to be nothing wrong with them. can somebody give suggestions to overcome this. Thanx in advance. Sharma.
Old   August 8, 2007, 13:56
Default Re: Urgent please!!!! Error messages in Fluent
red lemon
append case file can give spurious results due to differences in the cases. I would merge the meshes via utility tmerge or use TGrid then use file/write-bc and read-bc to apply the boundary conditions from the cases.
Old   August 8, 2007, 23:47
Sharma
Thanx for your suggestion, will try and get back to you.
problem of running parallel Fluent on linux cluster ivanbuz FLUENT 15 September 23, 2017 19:12
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
Urgent Help Needed!!! (regarding FLUENT UDF) dsen FLUENT 2 May 28, 2010 13:36
Fluent connection with simulink by TCP/IP Tanktruck Fluent UDF and Scheme Programming 1 June 28, 2009 12:56
Urgent help needed- FLUENT to ANSYS Omer Main CFD Forum 3 September 18, 2006 10:24
