Outlet pressure in a supersonic flow
Old   August 15, 2007, 10:30
Default Outlet pressure in a supersonic flow
chouki
Hello everybody, How we impose a given pressure at the outlet in a supersonic flow? Regards, Chouki,
Old   August 15, 2007, 14:48
Default Re: Outlet pressure in a supersonic flow
marius
it is an internal or external flow?
Old   August 16, 2007, 03:40
chouki
Dear Marius, It is a supersonic flow in a horizontal circular duct. Regards, Chouki
Old   August 16, 2007, 11:05
max
If the flow is supersonic all over your outlet face the backpressure you have defined as bc will be ignored by fluent anyway. This does make sense because no information of downstream pressure can be transferred upstream in supersonic flows and therefore is not required for the numerical solution
back pressure at exit for supersonic flow BigFrank FLUENT 6 April 24, 2014 16:13
Problems in pressure when using mass flow rate outlet rafiktharwat CFX 11 January 2, 2014 18:21
Disabling back flow/reversed flow for a pressure outlet? ksiegs2 FLUENT 0 April 28, 2011 16:31
Creating reversed flow at a supersonic outlet Stephen FLUENT 2 January 3, 2003 11:52
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
