August 16, 2007, 01:24 |
Surface roughness in laminar flow
I am not solving a laminar flow problem. In that do surface roughness value matters? Since I am under predicting the pressure loss value in a system? Where to input the surface roughness, I am not finding any place in wall BC. Thanks |
August 16, 2007, 02:45 |
Re: Surface roughness in laminar flow
In the Wall boundary conditions Panel.
August 16, 2007, 04:05 |
Surface roughness have NO influence on pressure drop at all in laminar flow. It is only Reynolds dependent: dP = rho * 64/Re * L/D * ½*V^2 -Dr. Flow Squad http://tinyurl.com/2gkjh8
August 19, 2007, 14:35 |
Hi
You can specify roughness height and roughness constant in the walls BC panel |
August 19, 2007, 15:52 |
Hi AAA, You can see the message of Dr. Flow Squad. The flow is laminar. Chouaib
nutRoughWallFunction and Surface Roughness Documented | AlanR | OpenFOAM Programming & Development | 64 | January 6, 2024 07:13 |
Surface roughness in Flow-3d | Marco | FLOW-3D | 3 | June 3, 2018 02:15 |
Surface roughness | alefem | FLOW-3D | 6 | June 3, 2010 12:49 |
Problem with capturing water-spreading for free surface flow | devesh.baghel | OpenFOAM | 2 | December 10, 2009 01:21 |
Laminar Flow | rvallejo | CFX | 1 | November 16, 2009 09:49 |
