Constant heat flux with uniform temperature
Old   April 18, 2003, 11:21
Default Constant heat flux with uniform temperature
Jake Lee
I am using Fluent to model heat transfer for flow inside a channel with constant heat flux boundary condition. Is there a way to impose a uniform wall temperature around the periphery (i.e. uniform wall temperature distribution in each cross-section) at the same time? I have tried giving the wall material a very high thermal conductivity (1e38) but there is still significant temperature variation in the wall periphery. Thanks, Jake
Old   April 21, 2003, 13:32
Default Re: Constant heat flux with uniform temperature
Jake Lee
Any pointer would be greatly appreciated. Thanks in advance.
Jake
Old   April 13, 2011, 22:08
Default Re
cdf_user is on a distinguished road
your heat transfer concepts are wrong. Read internal flows chapter form heat transfer incropera. if you specify a constant heat flux to the wall of the wall, the temperature of the wall HAS to change and CANNOT be constant along the direction of the flow.
cdf_user is offline   Reply With Quote
Temperature & Heat Flux Boundary jamesmaca FLUENT 5 December 11, 2019 05:16
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
constant heat flux Tobi OpenFOAM Pre-Processing 1 March 14, 2011 04:29
pipe flow with heat transfer Fabian OpenFOAM 2 December 12, 2009 04:53
BC for constant heat flux saidi Main CFD Forum 2 July 17, 1998 15:02
