how to define pressure drop formula in a pipe
Old   August 22, 2007, 08:02
Default how to define pressure drop formula in a pipe
Yessica Pomarinni
i have obtained a mathematical formula of pressure drop as a function of mass flow rate, with experimental data. I'd like to know how to impose a pressure drop in a pipe, given for the mathematical formula. I think a UDF is needed, for reading the mass flow rate and obtain the pressure drop with the formula. Some orientation or informatino about this would be helpfull.
Thanks ins advance.
Best regards.
Old   August 22, 2007, 08:48
Default Re: how to define pressure drop formula in a pipe
Joe
Just set the pressure drop you require via two pressure BCS.
Old   August 31, 2007, 12:09
Amit Bhansali
Hi, I am a graduate student from OSU and i would like to know the equation u derived for pressure drop as a function of mass flow rate. Is the equation derived by using Darcy's Weisbach equation? I am having some kind of same problem that deals between the two of these parameters. Please do send me a reply
UDF to define or adjust pressure??? engahmed FLUENT 0 July 6, 2010 18:19
What's meaning of pressure drop for fluid? qihongming Main CFD Forum 1 April 30, 2009 13:05
Pressure Drop - Please Help - Simple Pipe Flow Joe A. FLUENT 2 April 23, 2007 08:50
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
