FAN BC
Old   August 27, 2007, 23:41
Default FAN BC
sheila
Hi, I'm trying to simulate a propeller using fan bc. what I confuse is about the post processing.
if i input the pressure drop (delta p) and the velocity (V) at the inlet, what will be the output?
if the output is thrust (T), aren't we able to count T = delta p x A (disk area) directly. I think i missed something here.
Thank you in advance.
Sheila
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 11:30
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 04:54
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 08:24
Proper BCs for internal fan serezhkin CFX 3 July 28, 2010 10:04
Propeller Fan Curve Simulation Teng_YJ FLUENT 2 February 16, 2009 19:37
