October 31, 2011, 07:56 |
CPU Compatibility
Hi there, I'm currently building a PC to run Fluent, and I was wondering if it is compatible with an AMD APU A8 3850 Quad Core CPU. Technical support said they do not recommend any particular CPUs so I have signed up to ask the community directly.
Thank you in Advance |
November 7, 2011, 03:06 |
Rep Power: 17 |
Fluent is not particularly CPU dependant. AMD or Intel will work just fine. Hardware capacity is problem/mesh dependant. Amount of RAM is generally more important than no/speed of CPU's
Regards Luke |
November 7, 2011, 16:17 |
Vieri Abolaffio
Rep Power: 16 |
it is probably a more hardware section consideration, but i would not choose low-end, low - power, "office style" processors to perfrom cfd simulations. maybe intel i7 or amd buldozzer cpus are more suited for the job
stop when I run in parallel | Nolwenn | OpenFOAM | 36 | March 21, 2021 04:56 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
OpenFOAM 13 Intel quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 13 | February 5, 2008 05:26 |
OpenFOAM 13 AMD quadcore parallel results | msrinath80 | OpenFOAM Running, Solving & CFD | 1 | November 10, 2007 23:23 |
Dual Core CPU | hjasak | OpenFOAM Running, Solving & CFD | 5 | July 22, 2006 03:57 |
