urgent need for help
Hi all I have to model the flow and heat transfer in triangular channel .My problem is I dont able to mesh this channel when I mesh the adges and the faces the work is goen good but when I mesh the volume the fluent display an error message . Please can any one help me by guiding me to how to mesh the volumes with best regards and thanks
Re: urgent need for help
do you have any bad elemeny? i mean with bad skew angle or something like this?
Meshing the faces, what kind of mesh are you using? have you tried a Map or Submap mesh? If you made a Pave mesh, try these ones. Good Luck! |
I tried all type of mesh but the problem is the same the faces is meshed but the volume did not meshed .and the fluent disply error message about skewness .Not that my work is one microchannel i.e the dimension is very small in micron is that matter affect on the meshing thank you
umm...meshing is hard stuff i believe u may choose wrong type meshing in face and volume correct me if i wrong
