Error Display of FLUENT on LINUX FEDORA 7
Old   August 27, 2007, 14:43
Default Error Display of FLUENT on LINUX FEDORA 7
Gustavo Gondran Ribeiro
I have been working with FLUENT on LINUX FEDORA 7, simulation of my problem: that's OK, But when go to Display->Contours->Temperature, Error: Cannot find Display! Plot->XY->Pressure, Error: Cannot find Display!
Can somepody help me? please!
Thanks!
Old   August 27, 2007, 19:35
Default Re: Error Display of FLUENT on LINUX FEDORA 7
AAA
Hi
Are you choosing specifying a proper surface to display the results on?
One more thing. Is your scale right? Check if you are using the same scale (dimensions) in the simulations and the output.
Old   August 27, 2007, 21:18
Gustavo Ribeiro
No, I don't use proper surface
yes, I'm using the same scale in the simulation and the output
thank's
Old   August 28, 2007, 03:47
Felix
Are you sure that the DISPLAY environment variable is correctly set?
Old   August 28, 2007, 08:15
Gustavo Ribeiro
how to do this? I think that no!
please help me!
Old   August 28, 2007, 08:24
Felix
It's been some time since I last used Unix extensively, so I can only give some hints.
At a command prompt (shell prompt) type:
echo $DISPLAY
Assuming your computer is called "mypc" your system should return something like:
mypc:0
or
mypc:0.0
The DISPLAY variable is the place where the Fluent process looks if it wants to determine on which computer to look for a process to contact to have it's output displayed on screen.
Hope this helps.
Old   August 31, 2007, 11:19
cfd-newbie
Try this in a Terminal
fluent 2ddp -driver x11
then load your case and data and you should be able to display your data.
Old   August 31, 2007, 23:06
Gustavo Ribeiro
Thanks a lot! This way worked perfectly!
Thank you!
Fluent Linux and OS mortain FLUENT 9 September 15, 2009 12:10
Problem about Fluent on Linux hbinma FLUENT 3 July 6, 2008 10:49
Fluent on Linux Cluster george FLUENT 0 August 11, 2006 04:57
Parallel Fluent on Linux clusters Chengwang Lei FLUENT 3 November 24, 2004 02:05
Linux optimization for FLUENT Jacek FLUENT 9 May 23, 2002 03:11
