suction and blowing BC
Old   August 31, 2007, 06:13
Default suction and blowing BC
sheila
hI.. I want to know what BC n fluent that gives the suction and blowing effects.
I want to simulate an airfoil with suction and blowing part.
Thanks
Old   August 31, 2007, 09:02
Default Re: suction and blowing BC
Glenn
Blowing --- Total Presure Inlet or Mass Flow Inlet Suction --- Static Pressure Outlet or Mass flow Inlet with flow vector orientation pointing out of fluid volume.
Hope I understood your question correctly.
Old   September 3, 2007, 00:23
sheila
Hi glenn, thanks for your answer.
I tried both but then when I read the case file in fluent, the grid check was failed.
I use pressure inlet as the forward BC of the air doamain (surrounding the airfoil) and pressure outler as the rear BC. Fluent said that there are 2 adjacent cells of the pressure inlet.
I tried other BC and it seems that fluent only accept fan, interior, porous jump, radiator and wall for an object inside the domain. which one is the best? have you had any experience on it?
thanks
Old   September 3, 2007, 03:49
Luca
I tried many times to this in FLuent but never succeded. I wanted to model the transpiration. Let me know if you discover how to do that. Regards Luca
Velocity boundary condition: negative value (suction) val46 OpenFOAM 5 May 8, 2012 23:40
suction and blowing boundry condition brusly FLUENT 3 November 16, 2006 05:13
Suction Jets - StarCD M Patel Siemens 1 October 4, 2004 07:37
BoundaryLayer with blowing Max Nutini FLUENT 2 August 9, 2000 05:21
