September 14, 2007, 11:30 |
Gambit crashes when mesh volume Tet-TGrid
Hi have a geometry like this http://img407.imageshack.us/img407/5809/meshiz9.jpg I meshed the main faces around the profile and i want to mesh the volume using Tet/Hybrid - TGrid... Gambit simply crashes !! Does anybody knows what's going on and what to do ? Thanks!! Cyril |
September 14, 2007, 14:16 |
Re: Gambit crashes when mesh volume Tet-TGrid
Which version of Gambit? I've had better luck with the stability of Tgrid meshing with V2.3 than with V2.2. That is, meshing operations that caused a crash in V2.2 were ok in V2.3, albeit with a lot of skewness. We've tried V2.4 a few times but as of yet haven't seen differences.
September 15, 2007, 05:52 |
I have Gambit 2.1.6 Does it means that there is no solution than having a new version ??
Is there any trick or anything else I could do to mesh my geometry...? |
September 17, 2007, 02:23 |
hi Cyril I assume it is a skewness problem Before Gambit crashes, you should receive a message, which means you have a skewness problem at face number xxx.... Go and observe this face, you should easy solve your problem (In you geometry, you just need to merge some faces) ;o)
September 17, 2007, 03:18 |
Great, I'll try that. Thanks.
P.S: I don't have time to read the message as Gambit crashes quickly.. |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
mesh missing after import in fluent | morteza08 | FLUENT | 0 | July 23, 2010 02:22 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[GAMBIT] Placing Specific Mesh Nodes in a Volume Mesh | davisi | ANSYS Meshing & Geometry | 0 | November 12, 2009 07:44 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
