Sloshing
Old   September 6, 2007, 22:55
Default Sloshing
Lin
I am doing a sloshing problem. I define my boundary conditions as functions of time and don't have fluid draining from my tank(boundary condition is wall).
-The solver must be unsteady (1st order implicit)
-the multiphase model is obviously VOF. Turn on the implicit body force option
-the viscous model is laminar
-set the phases. The primary phase should be the lighter
-on the operating conditions panel, enable gravity and specify the operating density as the one of the lighter phase.
-on the boundary conditions panel, turn on the source terms and use my momentum source
-keep my URFs quite big (0.6 and 0.8 for pressure and momentum respectively, 1 for the other parameters)
-discretization schemes: BODY FORCE WEIGHTED for pressure, PISO for pressure velocity coupling (skewness correction=1, neighbour correction=1, turn on the skewness neighbor coupling), FIRST ORDER UPWIND for momentum.
-once I initialize the flow field to create an adaption register for patching the initial fluid location (adapt>region, then patch the liquid volume fraction solve>initialise>patch, select the volume fraction of the liquid as 1)
-keep my time step quite small(0.001).
This is my UDF
#include "udf.h"
double AlnrX;
DEFINE_ADJUST(Accl, domain) { double t;
t = RP_Get_Real("flow-time");
AlnrX = -0.0363*sin(1.1*t);
printf("time = %f\n",t); printf("accel = %f\n",AlnrX);
DEFINE_SOURCE(xmom_source, cell, thread, dS, eqn) { double pos[ND_ND]; double rho; double source;
C_CENTROID(pos,cell,thread);
rho = C_R(cell,thread);
dS[eqn] = 0.0; source = AlnrX *rho;
return source; }
But my calculation is wrong comparing with experiment. Please tall me what is wrong on my setting.
Thank you very much!
Lin
Old   September 7, 2007, 06:11
Default Re: Sloshing
Joe
How is it wrong?
Grid and timestep independance?
Higher order spatial and temporal discretisation?
Start with a simple dam breaking validation to check your numerics.
Force Window and sloshing mass satellite_control FLOW-3D 0 October 6, 2011 09:04
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
Calculating Sloshing mass in a cylinder satellite_control FLOW-3D 0 June 20, 2011 05:34
Sloshing frequency determination alastormoody11 STAR-CCM+ 0 January 20, 2011 22:40
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 11:21
