Too many VOF sub-timesteps problem
Old   September 10, 2007, 22:02
Default Too many VOF sub-timesteps problem
wanghong
hi,all
i am simulationg a free surface movement using VOF.when the mass flux of mass inlet is defined and time step is 0.002s,my computer tell me: "Updating solution at time level N... Error: Too many (3760548593) VOF sub-timesteps. The velocity field is probably diverging. Please check the solution, and reduce the time-step if necessary. Error Object: ()"
when time-step is 0.2s,error is following: "Updating solution at time level N... Error: Too many (274569734) VOF sub-timesteps. The velocity field is probably diverging. Please check the solution, and reduce the time-step if necessary. Error Object: ()". why? how to do it?
Old   September 11, 2007, 01:38
Default Re: Too many VOF sub-timesteps problem
garima chaudhary
I think u shud try with timp step of .000002 and then gradually reduce n keep no of iteration s per time step at first to 50 and also remove any convergence criteria.and then gardually decrease time step size and then max no of iteratiuon per time step to 20 and then enable convergence criteria
Old   September 11, 2007, 02:48
wanghong
i try it using 0.00002,but my computer rell me:"error:floating point error:invalid number. why? wanghongbjut@yahoo.com.cn
a problem of incompressible two phases(water and gas) with VOF Method zhangweisnoopy Main CFD Forum 9 August 12, 2011 08:25
Two-phase VOF problem scott copland FLUENT 3 March 15, 2007 07:25
Problem with VOF open channel modelling Biswanath Mahato FLUENT 1 September 14, 2006 04:20
A Problem with setting the time step in VOF model Le FLUENT 2 July 20, 2006 22:00
problem with VOF. Marc FLUENT 1 June 5, 2002 08:17
