help: the volume mesh has highly skewed elements |
September 17, 2007, 21:26 |
using GAMBIT to generate the mesh but the mesh volume mesh has highly skewed elements (Equisize skew >0.97). when input the mesh into FLUENT to do simulations, will the highly skewed mesh affect the simulations? Is there any way to make the local mesh better in GAMBIT? I tried to smooth it, but seems worse.
Thanks a lot in advance. |
September 17, 2007, 22:03 |
Re: help: the volume mesh has highly skewed elemen
Hello , the same thing happened wiz me while tryin to mesh smtg . I think , I think you have two choices : 1- increase the size of the elements that u r meshing . or 2- enter EDIT , then press on default and change the skeweness to be larger than 0.97 so that you can avoid this problem .. I guess if you successed in simulating the file on fluent , yeah it will be affected . hope that i helped u
September 18, 2007, 08:30 |
To reduce the amount of highly skewed elements you need to decrease the size of the elements in the skewed region. Depending on your geometry you could implement a size function in the highly skewed region in which the size of the elements increases further away from the skewed region. Otherwise you could decompose the geometry further so that your model can accomodate the element types but again this is dependant on your specific geometry
Neil |
September 18, 2007, 09:51 |
I would look for a reason for the mesh getting skewed.
Do you have a tube close to a wall you will for sure get highly skewed mesh, unless you make sure that there is not a sharp eged where the tube meet the wall, and there is a million other way that give you sharp egedes and it is har work to awoid them but you have to do it to be sure that you problem converge and get physical. Rasmus |
Display Modes | |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] surface mesh merging problem | everest | ANSYS Meshing & Geometry | 44 | April 14, 2016 06:41 |
Highly skewed and inverted volumes in wing mesh | makaero | FLUENT | 0 | December 8, 2009 19:32 |
what to do w/ highly skewed elements? (GAMBIT) | mike | FLUENT | 5 | June 2, 2007 22:10 |
Penetrating elements in extruded mesh | Michael P | CFX | 2 | May 20, 2005 08:06 |
