Problems in Meshing Cyclone
Old   September 16, 2007, 10:13
Default Problems in Meshing Cyclone
Sal
Can any one help me on meshing a geometry of a cyclone, I am having problems with generating a good quality mesh. I have the gambit ver 2.3 file. Thank you in advance
Sal
Old   September 16, 2007, 21:20
Default Re: Problems in Meshing Cyclone
fpingqian
Can you tell us the position that has problems?
Old   September 17, 2007, 05:39
chandra manik
First u have to mesh the cylone skin make it quet smooth do not to coarse, then mesh the volume, gambit will mesh your volume automaticaly refer to cyclone skin meshing
Old   September 19, 2007, 10:21
Sal
I the cyclinderical part of the cyclone which also has the inlet section. It does not allow me to mesh it properly and the velocity profiles that I obtain are completley different to the ones what people have reported before.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[ICEM] Problems about meshing the swept wing with cylinder end cap kepeng ANSYS Meshing & Geometry 3 June 15, 2010 05:21
Meshing problems using Gambit Vianney FLUENT 4 May 30, 2009 03:45
Meshing problems??? Nish CFX 3 August 22, 2000 02:57
Problems meshing a pie-shape cross-section bar-suggestions or workarounds needed Ricky Wong FLUENT 1 May 11, 2000 17:35
