Making arc on circle surface
Old   October 10, 2007, 15:30
Default Making arc on circle surface
rosol
Hi
Can any one help to plot or making an arc on the surface of sylindrical volume
thanks
Old   October 11, 2007, 05:56
Default Re: Making arc on circle surface
fluid
don't be too accurate in your questions....
Old   October 11, 2007, 13:55
rosol
I need to creat an arc in some place in a sylinder like the line plotting by surface -line/rake-line tool to be compute some variables along this arc or curved line
thank you
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 19:54
[snappyHexMesh] Add additional boundary layers to complex stl surface tobijingles OpenFOAM Meshing & Mesh Conversion 1 October 26, 2011 10:45
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 17:18
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
