Modify inlet B.C.
Old   October 21, 2011, 03:23
Default Modify inlet B.C.
Yu-Pei Chen
ypchen is on a distinguished road
Hi, everybody.
I want to get some position's data to be using at the inlet, for example, I take the temperature value at x = 0.01 m(my model is 2D), and the inlet temperature is also the value at x = 0.01m. I know I should use the UDF, but how can I do it by using UDF code ?
Thank you very much.
ypchen is offline   Reply With Quote
Old   October 21, 2011, 04:03
Amir's Avatar
Amir
Amir is on a distinguished road
you can use DEFINE_PROFILE macro!
There, you can provide your temperature as a function of space. (it's more efficient to fit a curve with your data)
Bests,
Amir
Amir is offline   Reply With Quote
Old   October 21, 2011, 09:17
Yu-Pei Chen
Hi,Amir
I had used DEFINE_PROFILE macro in my code, actually, my original inlet BC is dT/dX=0, but I don't know how to set it, so I want to get temperature value that near the inlet, creating a small temperature difference.
Old   October 21, 2011, 13:04
Amir's Avatar
Amir
Originally Posted by ypchen View Post
Hi,Amir
I know 3 procedures for your purpose:
1) the easiest one is to use UDS equation instead of energy equation (there are similar with some modifications); then you can easily set d/dn over boundaries.
2) use a UDF with DEFINE_PROFILE macro for your inlet and set temperature of each face equal to adjacent cell center value; it would be accurate for fine mesh near inlet.
3) you can also write a UDF for heat flux over your boundary; as you know, @ your inlet, heat flux is consist of convective and diffusive flux; with dT/dX=0, you have ignored diffusive flux, so you can set heat flux to convective one.
Bests,
Amir
Old   October 23, 2011, 21:27
Yu-Pei Chen
Thank for your help, Amir.
I'll try your ways, it seems very helpful for me.
Thank you again !
Old   October 24, 2011, 23:40
Yu-Pei Chen
Hi, Amir, I have some question about your suggestion :
---- How to get the adjacent cell value in UDF code ?
---- My B.C. type is pressure inlet, can I use DEFINE_HEAT_FLUX at the inlet ? If it can work, how to ignored diffusive flux in UDF code ?
thank you very much !
Old   October 25, 2011, 03:50
Amir's Avatar
Amir
use:
F_C0(f,t) , THREAD_T0(t) to access cell and its thread index. (refer to UDF manual table 3.2.24-25).
Oops! you're right; this can be done over wall boundaries. So you can use suggestions 1 or 2.
Bests,
Amir
Old   October 31, 2011, 09:51
Yu-Pei Chen
Hi,Amir
I follow your suggestion to useF_C0(f,t) and THREAD_T0(t) to access cell and its thread index. When I interpreted my udf, it's OK, but the error occured after I initialize my system. I post my code below :
DEFINE_PROFILE(inlet_temp,thread,position)
real temp_in ;
Thread *t ;
cell_t c0 ;
Thread *t0 ;
face_t f ;
begin_f_loop(f,thread)
c0 = F_C0(f,t);
t0 = THREAD_T0(f,t);
temp_in = C_T(c0,t0);
F_PROFILE(f,thread,position) =temp_in;
end_f_loop(f,thread)
can you see something wrong in my code ? thank you !
Old   October 31, 2011, 10:05
Amir's Avatar
Amir
check this and inform me:
 real temp_in;
 cell_t c0;
 Thread *t0;
 face_t f;
 c0 = F_C0(f,thread);
 t0 = THREAD_T0(f,thread);
Bests,
Amir
Old   October 31, 2011, 11:03
Yu-Pei Chen
Hi, Amir
I try the new code, but the same error still happend. The error was :
FLUENT received fatal signal (ACCESS_VIOLATION)
1. Note exact events leading to error.
2. Save case/data under new name.
3. Exit program and restart to continue.
4. Report error to your distributor.
Old   November 1, 2011, 02:07
Amir's Avatar
Amir
Hi, Amir
Dear friend,
you have a bug in your code; I correct it for you but you said that ther is not any problem in compilation before!!!
try this code: (I checked that as compiled UDF) .... there was extra argument for THREAD_T0. Also ensure you've activated energy equation and initialize that.
# include "udf.h"
 real temp_in;
 cell_t c0;
 Thread *t0;
 face_t f;
 t0 = THREAD_T0(thread);
Bests,
Amir
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
TimeVaryingMappedFixedValue for Direct Numerical Simulation inlet johndeas OpenFOAM 5 May 21, 2014 07:11
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 07:26
transitional inlet boundary condition kamp CFX 1 June 21, 2006 11:08
inlet turbulent B.C. ROOZBEH FLUENT 3 September 25, 2003 07:07
