October 29, 2007, 21:03 |
Pressure more accurate than velocity field?
Is it correct to assume that the pressure field in most CFD simulation on laminar incompressible flow is likely to be more accurate (ie. closer to the truth) than vector field?
Or put in another way, is it easier to get good pressure data compared to velocity? Easier in the sense that a not-so-good mesh and/or a first order momentum upwind can still produce reasonable pressure data. Thanks |
October 30, 2007, 11:11 |
Re: Pressure more accurate than velocity field?
I prefer to velocity, though knowing the pressure field can be use to find velocity field and also opposite condition.
Channel flow: Inlet pressure AND uniform velocity? | frmap1 | Main CFD Forum | 0 | April 15, 2010 10:32 |
Pressure Inlet Velocity | prapanj | OpenFOAM | 11 | June 23, 2009 11:15 |
custom pressure field at the faces | Souviktor | FLUENT | 0 | April 3, 2009 08:09 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
