Symmetry B.C. Not Working?
Old   October 25, 2007, 23:09
Default Symmetry B.C. Not Working?
XC
Dear All,
The physical flow/geometry is symmetric and I don't have any problem to set up the symmetry BCs and run my case.
However, when I check the result, the distribution (P & T) is not correct: For example, the "whole" distribution should be a "bell" shape. I used the symmetry condition to obtain one "half" bell, but mirroring the "half" bells gives a bell with a "dent" in the center. I tried different cases and it does not look like the problem of meshing.
Please help if you experienced similar issues. Many thanks.
xc
Old   October 26, 2007, 08:14
Default Re: Symmetry B.C. Not Working?
Leverkin
Hello there,
I had the same problem and i change my geometry so the plane or axis of symmetry lies on the x-axis and i set the B.C. from symmetry to axis. This worked for me.
Old   October 26, 2007, 09:36
XC
Hello Leverkin,
Thank you very much for your inputs.
Did you have a chance to ask for Fluent Technical Support why it happens? You are smart to change the symmetry to axis and make it work. However, what should we do if we have more than one symmetric BC, for example, 1/4 the whole domain? I just cannot believe Fluent fails for such a common CFD issue.
Thank you again for your help. Have a nice day.
xc
Old   October 27, 2007, 05:54
Leverkin
Hello there,
to tell you the truth i have not come up with such a proble again.
Try to set your BC from "symmetry" to "wall" with zero fluxes for all your values (just us symmetry works). Maybe this will lead you in the solution you seak.
Have a nice day.
Old   October 27, 2007, 11:14
XC
Hello Leverkin,
Thank you for your response. I tried the "slip" wall. Nothing is improved. Sad. Welcome any inputs. Thanks.
xc
Old   November 2, 2007, 02:21
Ahmed Yakyaki
Is it 2D OR 3D case?
Old   November 2, 2007, 14:12
XC
3D
[ICEM] Blocking and Symmetry BrolY ANSYS Meshing & Geometry 32 August 24, 2012 03:13
Symmetry or Axis B.C ?? L. Hamid Main CFD Forum 2 May 20, 2011 06:27
symmetry b.c nazari FLUENT 1 January 13, 2009 01:41
problem with Symmetry boundary condition Miri FLUENT 1 November 15, 2006 13:09
SYMMETRY + PERIODIC B.C....I need Help! JB FLUENT 6 January 14, 2005 07:03
